16 years agoDHCP superloop mode
Hello! Well, I'm facing this issue. Internichestack in superlop mode works correctly, DHCP too. The problem is this: when turning on the module, without ethernet cable connected, the DHCP clien...
16 years agoThe behavior you are describing occurs both in superloop and RTOS mode. The stack simply only attempts DHCP discovery on initial startup. You'll have to dig into the code and use some ingenuity if you want to change this behavior.
Jake
