16 years agoDHCP Failed to Assign IP
Dear Friends, my NIOS-II Board always failed to assign ip through dhcp (Through Which i am able to ping NIOS board with my machine earlier), and then code automatically assign static IP addre...
16 years agoHi, look at IP settings in your board application, especially at Gateway IP
If your board is directly connected to a PC, you should use a cross ethernet cable (or a cross adapter ).
