21 years agoDevice nodes: major, minor numbers
I have been using the Nios II IDE to rebuild and upload my romfs filesystem image to my uKit development board. I previously did not have a problem communicating via ttyS0. Now I am having...
21 years agoI will look at recompiling my ls command with the fix.
I have resolved my problem. I was getting an error indicating that the device didn't exist, so when I did the ls and the minor number wasn't there I assumed that this was the problem. What I forgot was that I had recently started a new kernel project whereby my nios serial support was not enabled. OOPS. After recompiling the kernel with serial uart support, the serial port worked properly. Sadly, it was a dumb mistake with a little deception added in. Thanks for your help.
