21 years agoDevice Node files
Hey, so I'm attempting to move my filesystem to a compact flash card, but I need to populate the /dev directory with actual device node files. The refrence guide only goes so far as to suggest using mknod or scripts available on the web. Where are these scripts? Is there any way to take advantage of the information in the /dev directory when I mount a working filesystem on the onboard flash of my Stratix board?
--Jordan1 Reply
There might be some nodes missing (don't remember of I had to add more, but it should get you on the way.
mknod dev/console c 5 1 mknod dev/full c 1 7 mknod dev/kmem c 1 2 mknod dev/kmsg c 1 11 mknod dev/mem c 1 1 mknod dev/null c 1 3 mknod dev/port c 1 4 mknod dev/ptmx c 5 2 mknod dev/random c 1 8 mknod dev/tty c 5 0 mknod dev/urandom c 1 9 mknod dev/zero c 1 5 mkdir dev/pts mknod dev/pts/0 c 136 0 mkdir dev/pty mknod dev/pty/m0 c 2 0 mknod dev/pty/m1 c 2 1 mknod dev/pty/m2 c 2 2 mknod dev/pty/m3 c 2 3 mknod dev/pty/m4 c 2 4 mknod dev/pty/m5 c 2 5 mknod dev/pty/m6 c 2 6 mknod dev/pty/m7 c 2 7 mknod dev/pty/s0 c 3 0 mknod dev/pty/s1 c 3 1 mknod dev/pty/s2 c 3 2 mknod dev/pty/s3 c 3 3 mknod dev/pty/s4 c 3 4 mknod dev/pty/s5 c 3 5 mknod dev/pty/s6 c 3 6 mknod dev/pty/s7 c 3 7 mkdir dev/vc mknod dev/vc/0 c 4 0 mknod dev/vc/1 c 4 1 mknod dev/vc/10 c 4 10 mknod dev/vc/11 c 4 11 mknod dev/vc/12 c 4 12 mknod dev/vc/13 c 4 13 mknod dev/vc/14 c 4 14 mknod dev/vc/15 c 4 15 mknod dev/vc/16 c 4 16 mknod dev/vc/17 c 4 17 mknod dev/vc/18 c 4 18 mknod dev/vc/19 c 4 19 mknod dev/vc/2 c 4 2 mknod dev/vc/20 c 4 20 mknod dev/vc/21 c 4 21 mknod dev/vc/22 c 4 22 mknod dev/vc/23 c 4 23 mknod dev/vc/24 c 4 24 mknod dev/vc/25 c 4 25 mknod dev/vc/26 c 4 26 mknod dev/vc/27 c 4 27 mknod dev/vc/28 c 4 28 mknod dev/vc/29 c 4 29 mknod dev/vc/3 c 4 3 mknod dev/vc/30 c 4 30 mknod dev/vc/31 c 4 31 mknod dev/vc/32 c 4 32 mknod dev/vc/33 c 4 33 mknod dev/vc/34 c 4 34 mknod dev/vc/35 c 4 35 mknod dev/vc/36 c 4 36 mknod dev/vc/37 c 4 37 mknod dev/vc/38 c 4 38 mknod dev/vc/39 c 4 39 mknod dev/vc/4 c 4 4 mknod dev/vc/40 c 4 40 mknod dev/vc/41 c 4 41 mknod dev/vc/42 c 4 42 mknod dev/vc/43 c 4 43 mknod dev/vc/44 c 4 44 mknod dev/vc/45 c 4 45 mknod dev/vc/46 c 4 46 mknod dev/vc/47 c 4 47 mknod dev/vc/48 c 4 48 mknod dev/vc/49 c 4 49 mknod dev/vc/5 c 4 5 mknod dev/vc/50 c 4 50 mknod dev/vc/51 c 4 51 mknod dev/vc/52 c 4 52 mknod dev/vc/53 c 4 53 mknod dev/vc/54 c 4 54 mknod dev/vc/55 c 4 55 mknod dev/vc/56 c 4 56 mknod dev/vc/57 c 4 57 mknod dev/vc/58 c 4 58 mknod dev/vc/59 c 4 59 mknod dev/vc/6 c 4 6 mknod dev/vc/60 c 4 60 mknod dev/vc/61 c 4 61 mknod dev/vc/62 c 4 62 mknod dev/vc/63 c 4 63 mknod dev/vc/7 c 4 7 mknod dev/vc/8 c 4 8 mknod dev/vc/9 c 4 9 mkdir dev/vcc mknod dev/vcc/0 c 7 0 mknod dev/vcc/a0 c 7 128 mkdir dev/mtdblock/ dev/mtdblock/0 b 31 0 dev/mtdblock/1 b 31 1 dev/mtdblock/2 b 31 2 dev/mtdblock/3 b 31 3 dev/mtdblock/4 b 31 4 dev/mtdblock/5 b 31 5 mkdir dev/mtd/ dev/mtd/0 c 90 0 dev/mtd/0ro c 90 1 dev/mtd/1 c 90 2 dev/mtd/1ro c 90 3 dev/mtd/2 c 90 4 dev/mtd/2ro c 90 5 dev/mtd/3 c 90 6 dev/mtd/3ro c 90 7 dev/mtd/4 c 90 8 dev/mtd/4ro c 90 9 dev/mtd/5 c 90 10 dev/mtd/5ro c 90 11
