20 years ago
Device Driver problem
hello Guys,
I am new to Nios and uClinux
I have written a simple device driver for a nios custom peripheral
After configuring the peripheral ,through the driver, the peripheral writes result to on-chip memory ... but i am unable to read the new value of memory location from the application c code
However , i get the correct (updated) value if i read the memory location in the driver itself
If i write another application in c , just to read the particular memory location, and execute it after excuting the first application, the memory location shows the correct value
So please suggest a way(s) to read the updated memory cotents in the same application
Thanking in anticipation,
Kunal
    --- Quote Start ---
    originally posted by kuni124d@Jun 29 2006, 12:53 PM
    hello guys,
    i am new to nios and uclinux
    i have written a simple device driver for a nios custom peripheral
    after configuring the peripheral ,through the driver, the peripheral writes result to on-chip memory ... but i am unable to read the new value of memory location from the application c code
    however , i get the correct (updated) value if i read the memory location in the driver itself
    if i write another application in c , just to read the particular memory location, and execute it after excuting the first application, the memory location shows the correct value
    so please suggest a way(s) to read the updated memory cotents in the same application
    thanking in anticipation,
    kunal
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=16532)
    --- quote end ---
    --- Quote End ---
    This sounds like a cache issue. I would start looking there first.
    Keith
    set bit 31 of the memory address , ie | 0x80000000 , to uncache the access in both driver and user app.
    --- Quote Start ---
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=16544)
    --- quote end ---
    --- Quote End ---
    Thanx , i shall follow your instructions. But , the memory location is in "On- chip" memory , which I beleive is not cached. There could be some other problem
    --- Quote Start ---
    originally posted by kuni124d+jun 30 2006, 01:44 pm--><div class='quotetop'>quote (kuni124d @ jun 30 2006, 01:44 pm)</div>
    --- quote start ---
    <!--quotebegin-hippo@Jun 30 2006, 07:02 AM
    --- quote end ---
    --- Quote End ---
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=16553)</div>
    [/b]
    --- Quote End ---
    Why do you mean the onchip memory is not cached?
    If you have d-cache in nios2, everything is cached unless you turn on bit31 of the address or use IORW macro .
