19 years agodevice driver module
I am currently writing a kernel device driver module. Added and modified Makefiles and Kconfig, and it seems to work. As I am actively developing and debugging code, it takes a long time everytime I change a line in this driver, and had to recompile the entire kernel. Does anyone how to just remake the module without having to make the entire kernel ?6 Replies
you can insert module with
and remove a module withinsmod mymodule
when your linux is running. However it is necessary to enable module loading and unloading feature, when you configure your kernel Have a nice dayrmmod mymodule - Altera_Forum
Thanks, but what i really want to know is there a quicker way to generate the module rather than going through
make make linux image; E.g. if I change a line of code when debugging the driver, it would take me 2 minutes to find out if there there is an error in the driver code. How do I make building the kernel driver module as a separate project ? - Altera_Forum
please have a look at
it works with the microtronix port. but i didn't test it with nioswiki buildroot ( i assume you are using this).1) http://forum.niosforum.com/forum/index.php?showtopic=2411&hl= 2) http://forum.niosforum.com/forum/index.php?showtopic=2522&hl= - Altera_Forum
Please read the "Build external modules" section in the wiki page,
http://nioswiki.jot.com/wikihome/operating...duleprogarmming (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux/moduleprogarmming) - Altera_Forum
Thanks hippo. I will give it a try.
wiki page updated again. to build module alone inside the kernel tree.
