20 years ago
Developing USB Mass storage drivers..
Hi guys,
I'm tasked to make our FPGA board (Altera Stratix II with NiosII core w/ Microtronix uCLinux version 1.4) able to write data out to a USB hard drive (like a LaCie drive). The USB port is OTG. Currently, the driver for writing data out to the USB port has been written, but it doesn't have the mass-storage protocol yet. I was wondering where can I learn how to so (newbie to developing drivers)?
We use CAST USB core. When I boot up the uCLinux, this is the message we are getting. (Just FYI ..if it provides any info about our board at all)
nios2-terminal: connected to hardware target using JTAG UART on cable
nios2-terminal: "USB-Blaster [USB-0]", device 2, instance 3
nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate)
Linux version 2.6.11-uc0 (jeff@Andromeda) (gcc version 3.4.1 (Altera Nios II 5.1
b73))# 938 Fri Aug 11 21:23:31 EDT 2006
uClinux/Nios II
Altera Nios II support © 2004 Microtronix Datacom Ltd.
setup_arch: No persistant network settings signature at 03FF0000
Built 1 zonelists
Kernel command line: root=/dev/mtdblock3 ro
PID hash table entries: 256 (order: 8, 4096 bytes)
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory available: 30368k/32768k RAM, 0k/0k ROM (1709k kernel code, 316k data)
Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
NET: Registered protocol family 16
SCSI subsystem initialized
usbcore: registered new driver usbfs
usbcore: registered new driver hub
comms: FPGA version: 1.2.9
JFFS2 version 2.2. (NAND) © 2001-2003 Red Hat, Inc.
NIOS serial driver version 0.0
ttyS0 (irq = 10) is a builtin NIOS UART
Serial: JTAG UART driver $Revision: 1.4 $
ttyJ0 at MMIO 0x87000000 (irq = 9) is a jtag_uart
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered
RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize
mtip_probe:eth0, 100000 Khz Nios (VSC8211) (PIO)
MoreThanIP 10/100/1000 Driver(v1.0), Linux 2.6.5 Apr2004
mtip_find_phy: found target PHY at address 2
mtip_probe:PHY reg17 = 0x1a34
mtip_probe:eth0, REV=0x00010023, (VSC8211) Phyaddr:0x02
WARNING: No MAC address found in flash at address 0x07fc0000. Using non-unique
MAC address of 00:07:ed:00:00:00
ADDR: 00:07:ed:00:00:00:
mtip_probe:eth1, 100000 Khz Nios (VSC8211) (PIO)
Altera NDK flash (AMD): Found 1 x16 devices at 0x0 in 8-bit bank
Amd/Fujitsu Extended Query Table at 0x0040
Altera NDK flash (AMD): CFI does not contain boot bank location. Assuming top.
number of CFI chips: 1
cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
cmdlinepart partition parsing not available
RedBoot partition parsing not available
Using Altera NDK partition definition
Creating 7 MTD partitions on "Altera NDK flash (AMD)":
0x00300000-0x00b00000 : "COP - romfs"
0x00000000-0x00300000 : "COP - loader/kernel"
0x00b00000-0x02000000 : "COP - jffs2"
0x02300000-0x02b00000 : "FEP - romfs"
0x02000000-0x02300000 : "FEP - loader/kernel"
0x02b00000-0x03000000 : "FEP - jffs2"
0x03000000-0x04000000 : "FPGA Code"
cast_usb: driver cast-hcd, 15 Jan 2006
cast_usb: USB Host Controller, irq 0
cast_usb: USB Host Controller, irq 2
cast-hcd cast-hcd: new USB bus registered, assigned bus number 1
usb usb1: Product: USB Host Controller
usb usb1: Manufacturer: uClinux 2.6.11-uc0 cast-hcd
usb usb1: SerialNumber: cast-hcd
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
CASTUSB: Timeout waiting for OTG negotiation
cast_hub_control: Jumper 3 installed
cast_hub_control: JUMPERREG: c0060000
Initializing USB Mass Storage driver...
usbcore: registered new driver usb-storage
USB Mass Storage support registered.
cast-udc-sas: loaded.
cast-udc-veh: loaded.
miser_sas gadget: Miser SAS, version: 15 Jan 2006
cast-udc-sas: registered gadget driver 'miser_sas'
cast-udc-sas: Entered IDLE state
cast-udc-sas: Entered PERIPHERAL state
miser_veh gadget: Miser VEH, version: 15 Jan 2006
cast-udc-veh: registered gadget driver 'miser_veh'
cast-udc-veh: Entered IDLE state
cast-udc-veh: Entered PERIPHERAL state
NET: Registered protocol family 2
IP: routing cache hash table of 512 buckets, 4Kbytes
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
VFS: Mounted root (romfs filesystem) readonly.
Freeing unused kernel memory: 68k freed (0x41da000 - 0x41ea000)
expand: from=/ramfs.img to=/dev/ram0
expand: from=/ramfs.img to=/dev/ram1
mtip_phy_configure:eth0, autoneg complete
PhyCtl0: 1000 PhySts1: 796D PhyID1: 000F
PhyID2: C4B1 PhyAdv4: 01E1 PhyRemcap5: 0020
mtip_phymac_synch:eth0 MR1: 0x0000796D
Autoneg'd
Link OK:
HalfD
10BASE-T
CMDCF: 0x00000603
1 Reply
    --- Quote Start ---
    originally posted by shachris23@Aug 14 2006, 09:11 AM
    hi guys,
    i'm tasked to make our fpga board (altera stratix ii with niosii core w/ microtronix uclinux version 1.4) able to write data out to a usb hard drive (like a lacie drive). the usb port is otg. currently, the driver for writing data out to the usb port has been written, but it doesn't have the mass-storage protocol yet. i was wondering where can i learn how to so (newbie to developing drivers)?
    we use cast usb core. when i boot up the uclinux, this is the message we are getting. (just fyi ..if it provides any info about our board at all)
    nios2-terminal: connected to hardware target using jtag uart on cable
    nios2-terminal: "usb-blaster [usb-0]", device 2, instance 3
    nios2-terminal: (use the ide stop button or ctrl-c to terminate)
    linux version 2.6.11-uc0 (jeff@andromeda) (gcc version 3.4.1 (altera nios ii 5.1
    b73))# 938 fri aug 11 21:23:31 edt 2006
    send me your config file pls
    uclinux/nios ii
    altera nios ii support © 2004 microtronix datacom ltd.
    setup_arch: no persistant network settings signature at 03ff0000
    built 1 zonelists
    kernel command line: root=/dev/mtdblock3 ro
    pid hash table entries: 256 (order: 8, 4096 bytes)
    dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
    inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
    memory available: 30368k/32768k ram, 0k/0k rom (1709k kernel code, 316k data)
    mount-cache hash table entries: 512 (order: 0, 4096 bytes)
    net: registered protocol family 16
    scsi subsystem initialized
    comms: fpga version: 1.2.9
    jffs2 version 2.2. (nand) © 2001-2003 red hat, inc.
    nios serial driver version 0.0
    ttys0 (irq = 10) is a builtin nios uart
    serial: jtag uart driver $revision: 1.4 $
    ttyj0 at mmio 0x87000000 (irq = 9) is a jtag_uart
    ramdisk driver initialized: 16 ram disks of 4096k size 1024 blocksize
    mtip_probe:eth0, 100000 khz nios (vsc8211) (pio)
    morethanip 10/100/1000 driver(v1.0), linux 2.6.5 apr2004
    mtip_find_phy: found target phy at address 2
    mtip_probe:phy reg17 = 0x1a34
    mtip_probe:eth0, rev=0x00010023, (vsc8211) phyaddr:0x02
    warning: no mac address found in flash at address 0x07fc0000. using non-unique
    mac address of 00:07:ed:00:00:00
    addr: 00:07:ed:00:00:00:
    mtip_probe:eth1, 100000 khz nios (vsc8211) (pio)
    altera ndk flash (amd): found 1 x16 devices at 0x0 in 8-bit bank
    amd/fujitsu extended query table at 0x0040
    altera ndk flash (amd): cfi does not contain boot bank location. assuming top.
    number of cfi chips: 1
    cfi_cmdset_0002: disabling erase-suspend-program due to code brokenness.
    redboot partition parsing not available
    using altera ndk partition definition
    creating 7 mtd partitions on "altera ndk flash (amd)":
    0x00300000-0x00b00000 : "cop - romfs"
    0x00000000-0x00300000 : "cop - loader/kernel"
    0x00b00000-0x02000000 : "cop - jffs2"
    0x02300000-0x02b00000 : "fep - romfs"
    0x02000000-0x02300000 : "fep - loader/kernel"
    0x02b00000-0x03000000 : "fep - jffs2"
    0x03000000-0x04000000 : "fpga code"
    cast_usb: driver cast-hcd, 15 jan 2006
    cast_usb: usb host controller, irq 0
    cast_usb: usb host controller, irq 2
    cast-hcd cast-hcd: new usb bus registered, assigned bus number 1
    usb usb1: product: usb host controller
    usb usb1: manufacturer: uclinux 2.6.11-uc0 cast-hcd
    usb usb1: serialnumber: cast-hcd
    hub 1-0:1.0: usb hub found
    castusb: timeout waiting for otg negotiation
    cast_hub_control: jumper 3 installed
    cast_hub_control: jumperreg: c0060000
    initializing usb mass storage driver...
    usb mass storage support registered.
    miser_sas gadget: miser sas, version: 15 jan 2006
    cast-udc-sas: entered idle state
    cast-udc-sas: entered peripheral state
    miser_veh gadget: miser veh, version: 15 jan 2006
    cast-udc-veh: entered idle state
    cast-udc-veh: entered peripheral state
    net: registered protocol family 2
    ip: routing cache hash table of 512 buckets, 4kbytes
    tcp established hash table entries: 2048 (order: 2, 16384 bytes)
    tcp bind hash table entries: 2048 (order: 1, 8192 bytes)
    tcp: hash tables configured (established 2048 bind 2048)
    vfs: mounted root (romfs filesystem) readonly.
    freeing unused kernel memory: 68k freed (0x41da000 - 0x41ea000)
    phyctl0: 1000 physts1: 796d phyid1: 000f
    phyid2: c4b1 phyadv4: 01e1 phyremcap5: 0020
    mtip_phymac_synch:eth0 mr1: 0x0000796d
    autoneg'd
    link ok:
    halfd
    10base-t
    cmdcf: 0x00000603
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=17577)
    --- quote end ---
    --- Quote End ---
