20 years agoDeveloping a Webserver to control Hardware
Hi, I would like to develop a Webserver on a Stratix 1s10 Development Board. Should I use standalone LwIP Stack or the socket Library from uCLinux. Witch is the advantage of this two Stacks? My...
20 years ago<div class='quotetop'>QUOTE </div>
--- Quote Start --- Can I control hardware with the boa webserver or should I use LwIp to programm my own webserver?[/b] --- Quote End --- i haven't tried boa webserver yet, so don't have the experience to answer your question. I think you need something like cgi in conjunction with the webserver. there are some people, who are working with the boa web server. it would be a good idea to ask them; check this link: <div class='quotetop'>QUOTE </div> --- Quote Start --- http://forum.niosforum.com/forum/lofiversi...x.php/t4414.htm (http://forum.niosforum.com/forum/lofiversion/index.php/t4414.htm)[/b] --- Quote End --- if trying to use LwIP you might have to reinvet the wheel (develop webserver) hope, it will help you.
