11 years agoDeveloping a DVI to USB video capture program
Hi guys, I'm developing a DVI grayscale video capture and outputting the stream of video serialized via USB. Since the normal USB won't handle data transmission at 800x600 resolution, ​13...
11 years ago --- Quote Start --- Hi, One of Altera's megafunction partner has something which is of your interest. Please visit following: http://www.slscorp.com/index.php. ( In that, look into "Image Acquisition using USB3.0 IP core" ). Hope this would help. Cheers, Bhaumik --- Quote End --- Unfortunatelly i can't use USB 3.0, USB 2.0 is way more common around here. I'll try to cram the data using compression. I've taken a turn away from UVC, since i only need to output the pixel values to the USB, i'm thinking about designing a USB bulk endpoint, but i don't know if the Cypress EZ-OTG on the DE2-115 can handle it. Could anyone point me to some reference design? As for compression, opencores has a JPEG encoder that might suite my needs (http://opencores.org/project,mkjpeg) and i'll stick with it for now. I'll focus on building the USB application for now.
