20 years agodev board CF interface speed
doing some speed tests on my altera 1c20 deb board. Ive done the following. mount a CF thats been formatted FAT and has a 1MiB file on it called speed cat speed > /dev/null and time the re...
20 years ago<div class='quotetop'>QUOTE </div>
--- Quote Start --- I will be using the stock CF interface that is available from the "Downloads -> Tested IP" section of this forum with the 16 MB Sandisk CF card that is included with the DSP Development Kit.[/b] --- Quote End --- Is that the same one that is in the kits/nios2/examples/verilog/<board>/linux? Its not clear from the docs if the dev kit contains that version of the IDE interface.
