20 years agodev board CF interface speed
doing some speed tests on my altera 1c20 deb board. Ive done the following. mount a CF thats been formatted FAT and has a 1MiB file on it called speed cat speed > /dev/null and time the re...
20 years agoAre you using the stock IDE CF interface provided in the example code or a different one? I haven't had a chance to run that test yet. Hopefully, I will find some time tomorrow. I will be using the stock CF interface that is available from the "Downloads -> Tested IP" section of this forum with the 16 MB Sandisk CF card that is included with the DSP Development Kit.
