20 years agodev board CF interface speed
doing some speed tests on my altera 1c20 deb board. Ive done the following. mount a CF thats been formatted FAT and has a 1MiB file on it called speed cat speed > /dev/null and time the re...
20 years agoHi smithbone,
Sounds like your CF is plenty fast enough. We have a Nios II CF interface working on an Altera DSP Development Kit board. On Monday, I will try the replicate the same type of test you mentioned in your orginal post and let you know the results.cat speed > /dev/null and time the results. Also, based on the calculations made in your orginal post, I'm assuming that "MiB" = mebibyte = 2^20 = 1024 ^2 = 1,048,576 bytes? Is that correct? I wasn't familiar with the "MiB" acronym until I looked it up. I find it interesting that the "mebi" prefix was created to avoid the confusion between what the "mega" prefix meant (1,000,000, 1,048,5467, or even 1,024,000 bytes). You learn something new everyday.
