20 years agodev board CF interface speed
doing some speed tests on my altera 1c20 deb board. Ive done the following. mount a CF thats been formatted FAT and has a 1MiB file on it called speed cat speed > /dev/null and time the re...
20 years agosmithbone,
What is the max. sustained read transfer rate specified by the Compact Flash manufacturer? I realized that this is probably not your bottleneck, but once your initial problem is repaired it would good to know what rates are theoretically possible given the CF itself is the limiting factor.
