20 years agoDesigns without Nios Processor
I am a beginner in using Altera Nios Development Board. I am trying to test simple logic on the FPGA Board without using NIOs 2 Processor. Can anyone tell me if this is possible. I am doing somet...
20 years ago --- Quote Start --- originally posted by legendbb@May 11 2006, 08:13 AM check settings -> ununsed pins --> set as inputs, tri-stated
nios ii development board doesn't not necessarily to be used only for nios ii processor design. you will see this by simply connection design.
if failed check project global settings.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15293)
--- quote end ---
--- Quote End --- Thanx for your reply... my deisgn worked the moment i changed the unused pins to "set as inputs,tri-stated"
