16 years agoDesign with MMU and on my de2 board
I build a design with MMU and tried it on my de2 board. When I compile uclinux for my hardware platform I encounter different problems. First I make a board definition for my de2. In folde...
16 years agoGood idea. We could make a U-boat which will boot from the CFI flash and
and let u-boot "boot" the linux kernel from the SD card. Both boards (DE0/DE2) are no different when you compare the sizes of the SDRAM and the FLASH memory. I try to get U-boot running and will keep you informed. I'm Also curious to read your results.
