16 years agoDesign with MMU and on my de2 board
I build a design with MMU and tried it on my de2 board. When I compile uclinux for my hardware platform I encounter different problems. First I make a board definition for my de2. In folde...
16 years ago --- Quote Start --- Hi, I met the problem like you in DE0 board which has 8MB SDRAM too. To my opinion, maybe it is not correct, zImage file is a zip file. It must be unzip or uncompressed before being mapped to memory. So in fact the true kernel ran on the memory is lardger than 8MB. One way to test this is that running the same system on the other board which has 16MB or lardger SDRAM, and then use
ps -v
to see space used of the memory. If my thought is wrong, please fogive me. --Smarter.UJS --- Quote End --- I don't have a board with 16 MB SDRAM! Is there not a possibility to build a smaller kernel?
