20 years agoDesign consideration help - Memory tester
Hello, I was hoping you could just review my design plan and tell me any relavent tips or lessons learned you might have. My board will have on chip memory, SDRAM and Flash. I'd like to...
20 years ago --- Quote Start --- originally posted by kwolfe@Aug 8 2006, 11:54 AM i really appreciate your help slacker. thanks.
hopefully i can pick your (or anyone elses) brain for one last issue. i've loaded the mem test program onto my development board but adjusted it so that i'm running out of the ext_ram (sram) and am trying to exercise the test routine on the sdram.
i'm running into an issue where i get data corruption (the program 'crashes') if i run the test on addresses starting at 0x0100.0000 (which is sdram_base). however, i have no issues running the test at 0x0100.01c8 (vma + lma as reported in the objdump) and beyond.
am i understanding it correctly that my sdram addresses are simply adjusted during the compile? therefore, when i run the test at sdram_base, i'm in fact really adjusting some other memory in the system space? if so, is there any way to dynamically hard code in what the sdram addresses will be? or am i just way off and have a seperate issue at hand.
thanks again,
keivn
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=17450)
--- quote end ---
--- Quote End --- You're probably overwriting the code located at your Exception Address. Change this to something other than SDRAM (in SOPC Builder) and recompile. Regarding your addressing question, it's absolute, but the switch fabric only makes the connections (master<=>slave) where necessary. SDRAM_BASE will always be SDRAM_BASE to those masters (CPU-IM, CPU-DM, DMA) that are connected to it. - slacker
