19 years agoDeleteable files
What files can I delete when cleaning up? Obvious ones that spring to mind are: "talkback" .XML files "db" .TDF/.CDB/.HDB (usually with bracketed "version numbers") "OBJ" .D and .O fil...
19 years agoYou can check and maybe update:
http://nioswiki.jot.com/versioncontrol (http://nioswiki.jot.com/versioncontrol) if you placed components into the project other than the Nios, you should keep the HDL source and its symbol if used The reconstruction sequence may have other steps if complex configurable components are used like the DDR, which requires the generation of timing scripts. IzI
