19 years agoDeleteable files
What files can I delete when cleaning up? Obvious ones that spring to mind are: "talkback" .XML files "db" .TDF/.CDB/.HDB (usually with bracketed "version numbers") "OBJ" .D and .O fil...
19 years agoBy cleanup do you mean check in (i.e. the minimal set of files you need). Just remember if you start deleting db folder files and have incremental compilation turned on you'll have to do a full compilation next time.
Typically when I go to store off a minimal set I keep these around: ptf qsf qpf bdf (top level) component folders software folders (without /debug or /release) sof (so that if I come back I don't have to regenerated and compile again)
