13 years agoDelayed Interrupt
Nios-II response to Continuous interrupt is delayed (sometime), due to this i am loosing my data what precaution should i take to handle this issue please have a look on print screen of m...
13 years ago --- Quote Start --- my Qsys not opening my sopc file it display only clock is it some kind of license issue i am using quartus 11.0 sp1 --- Quote End --- How did you design your system before? IIRC Qsys in Quartus 11.0 doesn't open automatically the design and presents you the basic clock+reset default system; you simply have to load your actual design from File menu. If the TC solution is not enough for you I'd follow dsl's tips, especially the alternate register set and the fifo.
