15 years agoDebugging user space app on uClinux with MMU "hangs" system
Dear all, I'm trying to debug a user space application on my uClinux/NIOS2 system with MMU, following the instructions in the NIOS Wiki under www(dot)nioswiki(dot)com/OperatingSystems/UClinux/...
15 years agoThanks alot, Hippo!
Now I can debug with gdb running on Ubuntu-Linux which is great! Working with the NIOS2 gdb under Windows/cygwin however does not work yet. I'm using an Altera toolchain as installed in C:\altera\91\nios2eds\bin\nios2-gnutools\H-i686-pc-cygwin\bin Is there a similar trick I can use on Windows or shall I just forget about debugging under Windows/cygwin? Kind regards, Gerald
