21 years agoDebugging Legacy Mode
I want to run Insight to debug a NiosII Legacy build. OCI/JTAG is not one of the options in the debugging communications list. (only uart) Can someone please tell me how to do this.
The Core (/s) has a JTAG debug module setup and nd program.srec acts like it is going to work (connects, seems to download), but gdb nevers comes up. (Progress: .....c then nothing) The other (less desirable) option is to debug/run Insight over the uart. Or can I add a JTAG Uart and use the IDE? What's the best practice here? Thanks, Ken1 Reply
Ok, here are some irritating bugs for those who have asked. Maybe it will save some time for someone.
I found that I could n2d a small test program if I nb'd it and it created a program.elf file. So n2d test.elf works. But, when you build a program using the sample Makefile it creates an obj/ dir and puts most of the output in there, but the .elf file is actually named .out. n2d will not work with this file, so I coppied obj/program.out to ./program.elf. Now n2d program.elf exits immediately with "can't create /tmp/prog_setup.gdb - permission denied". So chmod -R /tmp and still no joy. (same error) Turns out the .elf file needs to be in the obj/ directory so the magic incantation is to create a obj/program.elf now... n2d obj/program.elf works! (note that nd obj/program.out used to work with NiosI) You can search and replace all .out with .elf in the Makefile to make it go easier. Ken
