fa_fpga_enthusiast
1 year agoDebugging Issue with Nios® V Processor Using Ashling RiscFree IDE on Agilex® 7 FPGA
Hello, We are encountering an issue while debugging our application on the Nios® V processor implemented on an Agilex® 7 FPGA, using the Ashling RiscFree IDE. The problem occurs after the first su...
fa_fpga_enthusiast
1 year agoHello,
Thanks for your response!
We are currently using Quartus Prime Pro 23.4 since we work with both Nios II and Nios V. We plan to upgrade to a newer version in the future.
For now, we have found a workaround: Before terminating the debug session, we use the "Restart a process or debug target without terminating and re-launching" button in the Ashling RiscFree IDE. This forces the debugger to jump to the beginning of the application before termination, allowing the next debug session to start properly. However, we would prefer to avoid this workaround.
We will update you once we test with a newer version of Quartus Prime Pro, but this will take place later.
Best regards.
