19 years agoDebugging eCos
Hello Community,
I have some problems with eCos and debugging! I use the Altera Stratix Development Board. There are a JTAG Interface. Now I want to develop an application for eCos but I can´t debug any application with the JTAG interface. If I want to debug an internal eCos function there occurs an "no sources found" error! What I have to reconfig in my ConfigTool to debug applications and eCos functions with the JTAG interface? Or I have to debug with RedBoot? When I build a RedBoot Library I got an global pointer exception! I trying with the Linke -G0 Flag but it does´t work! Can anybody help me?2 Replies
I have found my failture! I had the "Build common GDB stub ROM image" enabled. This are Global Build options: - Global Compiler settings: -g -G0 -O0 ... - Global Linker settings: -g -G0 ... - Build common GDB stub ROM image: disabled regards, neowork - Altera_Forum
Quote:- What I have to reconfig in my ConfigTool to debug applications and eCos functions with the JTAG interface?
Ans :- In the Nios2ConfigTool, eCos HAL -> Nios2 architecture ->Debug Device Make it /dev/uart1 Similarly select the console device also based on your need. Hope this is what u meant! Thanks Akhil
