Oliver_I_Sedlacek
Contributor
2 years agoDebugger wont connect to NIOS II hello world on Cyclone GX development board
The Cyclone 10GX seems to configure from the programmer but Eclipse fails to connect though the embedded download cable. I only got this far by checking the 'Ignore mismatched system ID' and 'I...
wwanalim_intel
Contributor
2 years agoHi,
I already test this design and it working on our side. Testing is using the Cyclone 10 (10CX220YF780E5G) and Quartus Prime Pro Edition 23.1. This design was build according to this document https://www.intel.com/content/dam/support/us/en/programmable/support-resources/fpga-wiki/asset02/nios-ii-hello-world-a10.pdf but for the Cyclone 10.
After I built the project, I programed the .sof and able to "Run as > NiosII hardware " in Eclipse and print out hello world in the console. You can try on your board and let us know.
I sent the design to your email and also attached it below this reply.
Disclaimer - This is not official design from Intel, you may use on your own risk.
- wwanalim_intel2 years ago
Contributor
The design attached on this reply.
