16 years agoDebugger launch failure
I am working on a nios based design using a EP3C25. I was initially using the Bemicro dev board for test and debug and everything was fine, but now I am trying to work with the custom hardware and ca...
16 years agoI found what was causing the problem. It turns out that, at least on my PC, the Arrow usb blaster driver for the Bemicro dev board was conflicting with the standard usb-blaster driver. Once I removed the arrow usb blaster driver, I was able to launch the debugger with the custom hardware.
