20 years agoDebugger and disassembly.
Hello. How to make steps and set breakpoints in disassembly? for example i have following code. g_unOnchipRamBase = ONCHIP_RAM_BASE;
0x0100046c <InitIHEX+12>: movhi r2,528
0x01000470 <I...
20 years agoHi,
1. You can set a breakpoing but double click the left edge of the line. 2. <div class='quotetop'>QUOTE </div> --- Quote Start --- How to execute code by single instruction in disassembly.[/b] --- Quote End --- In Debug Perspective, there is a tool in tool bar, named Use Step Filter/Step Debug, enable it then you can step in disassemble code. David
