21 years agoDebug with nios2-elf-insight
Hi there, I'm having trouble getting the nios2-elf-insight debugger working with a Nios II system on custom hardware. At this stage I'm using the example code supplied with eCos. Comm...
21 years agoIt looks like you are running an old version of the tools. If you upgrade to the latest release (1.1), you should get a more informative error message which will hopefully help you diagnose the underlying problem.
