16 years agoDebug user space application with MMU
I am trying to use the gdbserver as described here:
http://nioswiki.com/linux/debug_user_space At some point, this was working, but sometimes it wouldn't work and now I haven't had it working for a while. The application and gdb dies on a crash and doesn't let me debug. This isn't just this particular crash, I've had this happen with almost every crash while developing. On the server: --- Quote Start --- root:/> gdbserver localhost:9999 myprogram Process myprogram created; pid = 50 Listening on port 9999 Remote debugging from host 192.168.100.28 <program output...> Child terminated with signal = b Child terminated with signal = 0xb (SIGSEGV) GDBserver exiting root:/> --- Quote End --- On the client: --- Quote Start --- Program terminated with signal SIGSEGV, Segmentation fault. The program no longer exists. (gdb) backtrace No stack. --- Quote End --- Any advice? Also, the wiki says "we will add the gdbserver source to uclinux-dist later" -- is there any progress on this? Could the gdbserver currently in uclinux-dist work?16 Replies
Debugging after a crash might be difficult. Are you sure it's just with NIOS ?
I just read a good book about working with gdb: the art of debugging with gdb, ddd and eclipse: for professionals and students (http://www.amazon.de/art-debugging-gdb-eclipse-professionals/dp/1593271743/ref=sr_1_3?ie=utf8&s=books-intl-de&qid=1266605020&sr=8-3) by Norman Matloff und P. J. Salzma -Michael - Altera_Forum
In the cases when I could run the program on my PC, I could debug the crash using gdb, so it is something with the NIOS gdbserver provided with the mmu toolchain.
Just wanted to add that breakpoints don't work either, with the same result, the program just terminates:
Program terminated with signal SIGTRAP, Trace/breakpoint trap. Not having the debugger available is really eating up a lot of time :-( - Altera_Forum
--- Quote Start --- Just wanted to add that breakpoints don't work either, with the same result, the program just terminates: --- Quote End --- When the debuggee program crashes, the 'gdbserver' will terminate itself. So please get debuggee's 'coredump' file by setting 'ulimit -c ***', for example in your 'bash', And copy it to your PC, and read it by Nios's 'gdb' with the command 'core-file core'. I think that you can reach the position which causes the crash. Then set a breakpoint there and... And don't forget to compile your program with the option switch '-O0'. --- Quote Start --- Program terminated with signal SIGTRAP, Trace/breakpoint trap. --- Quote End --- SIGTRAP? Really? Kazu - Altera_Forum
I realized when somebody mentioned it in the other thread on this topic (http://www.alteraforum.com/forum/showthread.php?t=19322) that I am not actually quite following the directions there.
I am not using
but instead the libs in the romfs:set solib-absolute-prefix ~/nios2-linux/toolchain-mmu/x86-linux2/nios2-wrs-linux-gnu/libc
Since all the libraries I am using need to be on the device for the application to run, I think this should not make a difference.set solib-absolute-prefix /data/nios/nios2-linux/uClinux-dist/romfs/ - Altera_Forum
--- Quote Start --- When the debuggee program crashes, the 'gdbserver' will terminate itself. So please get debuggee's 'coredump' file by setting 'ulimit -c ***', for example in your 'bash', And copy it to your PC, and read it by Nios's 'gdb' with the command 'core-file core'. I think that you can reach the position which causes the crash. Then set a breakpoint there and... And don't forget to compile your program with the option switch '-O0'. --- Quote End --- I am trying to use a core file now. I am running `nios2-linux-gnu-gdb mynios2program`, with set solib-absolute-prefix /data/nios/nios2-linux/uClinux-dist/romfs/ in .gdbinit. Then core-file mycorefile, but all I can get is:warning: Couldn't find general-purpose registers in core file. # 0 0x00000000 in ?? () - Altera_Forum
--- Quote Start --- I am trying to use a core file now. I am running `nios2-linux-gnu-gdb mynios2program`, with set solib-absolute-prefix /data/nios/nios2-linux/uClinux-dist/romfs/ in .gdbinit. Then core-file mycorefile, but all I can get is:
--- Quote End --- Do you have enough space for the core dump file? For example, ulimit -c unlimiled Kazuwarning: Couldn't find general-purpose registers in core file.# 0 0x00000000 in ?? () - Altera_Forum
I am debugging a user application and I have some doubts, and maby someone can answer my questions. My application produces a segmentation fault, I suppose that a segmentation fault provoke a core dumped, is this true? If I want to have core dumps in uClinux, as kazuyasu commented in last posts I have to insert the command : ulimit -c unlimited. But where is it in the configuration kernel?, I haven't found. And my last question is, is the core file created in /proc/sys/kernel?, if not where is it found? Many thanks - Altera_Forum
--- Quote Start --- My application produces a segmentation fault, I suppose that a segmentation fault provoke a core dumped, is this true? --- Quote End --- Yes, but the dumping is limited by 'core file size', and it's 0 by default. --- Quote Start --- I have to insert the command : ulimit -c unlimited. But where is it in the configuration kernel?, I haven't found. --- Quote End --- 'ulimit -c ***' that I mentioned before is an internal command of 'bash' and you don't need to configure your kernel in general. See also http://linux.die.net/man/3/ulimit --- Quote Start --- And my last question is, is the core file created in /proc/sys/kernel?, if not where is it found? --- Quote End --- In general, the core dump file is made in your 'current working directory'. http://linux.die.net/man/5/core Kazu - Altera_Forum
Hi Kazu,
I have changed the shell to ash and now I can see the core file. Many thanks
