20 years agodebug for Ethernet driver
I try to use debug mode to debuging LAN91C111 driver, but I can not set break pointer for the driver. Does any one know how to set break pointer in the altera_avalon_lan91c111.c? Thank you! ...
20 years ago --- Quote Start --- originally posted by david_wu@Mar 24 2006, 12:29 AM i try to use debug mode to debuging lan91c111 driver, but i can not set break
pointer for the driver. does any one know how to set break pointer in the
thank you!
david
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=13738)
--- quote end ---
--- Quote End --- Dear, David! The file altera_avalon_lan91c111.c should be using with UCOS-II rtos and LWIP (tcp-ip protocol stack). If you wish debug this driver you should create app for UCOS-II. See the examples! Some standart functions for LAN91C111 are "init", "rx" and etc. You can set break points to these functions.
