16 years agoDE3 with 88E1111 and TSE error
I'm trying to get the GigE network working on my DE3 with Marvell PHY. I'm using the SLS driver. Here's the error. If I remove the MMU in SOPC Builder and run SSS, it works fine. Any ideas?
Linux version 2.6.30 (akoski@wsip-24-234-74-196) (gcc version 4.1.2)# 66 Tue Jul 6 15:37:14 PDT 2010 console [early0] enabled Early printk initialized Linux/Nios II-MMU init_bootmem_node(?,0x31d, 0x0, 0x10000) free_bootmem(0x31d000, 0xfce3000) reserve_bootmem(0x31d000, 0x2000) Built 1 zonelists in Zone order, mobility grouping on. Total pages: 65024 Kernel command line: NR_IRQS:32 PID hash table entries: 1024 (order: 10, 4096 bytes) Dentry cache hash table entries: 32768 (order: 5, 131072 bytes) Inode-cache hash table entries: 16384 (order: 4, 65536 bytes) We have 65536 pages of RAM Memory available: 256512k/3187k RAM, 0k/0k ROM (1876k kernel code, 1310k data) Calibrating delay loop... 49.35 BogoMIPS (lpj=246784) Mount-cache hash table entries: 512 net_namespace: 716 bytes NET: Registered protocol family 16 init_BSP(): registering device resources altera_tse_mdio.0: failed to claim resource 2 ------------[ cut here ]------------ WARNING: at /home/akoski/aek/vhdl/uClinux-working1/nios2-linux/linux-2.6/drivers /base/core.c:123 device_release+0x80/0x84() Device 'altspi.2' does not have a release() function, it is broken and must be f ixed. Stack from cf820e18:<0> <0> cf820e3c<0> c000f8fc<0> cf81dd20<0> c02245c4<0> fffffff0<0> 00000000< 0> c000f980<0> c0211a68<0> <0> cf820e44<0> 00000000<0> c00fb384<0> cf82d800<0> c022028c<0> c00d4dc8< 0> c02202a8<0> c00d4d84<0> <0> 00000004<0> c00d5758<0> c022028c<0> c022027c<0> c00d4cb0<0> c023f3e8< 0> c023f3e8<0> c00fa1bc<0> <0> c00fee30<0> c00fef08<0> 00000001<0> c00fef8c<0> 00000001<0> 00000000< 0> c023fe84<0> c022f998<0> <0> c030d020<0> c022f9f4<0> 00000000<0> c0000210<0> 00000000<0> deadbe00< 0> 00000000<0> c00d3de0<0> <0> c00939c8<0> c0222944<0> 0000004d<0> cf81a0e0<0> c03173e0<0> 0000001f< 0> c0093c6c<0> cf81a140<0> Call Trace:<0> <0> [<c0036684>]<0> [<c0090000>]<0> [<c000252c>]<0> [<c000c1d4>]<0> <0> [<c0002490>]<0> [<c000104c>]<0> [<c0002520>]<0> ---[ end trace 4eaa2a86a8e2da22 ]--- ------------[ cut here ]------------ WARNING: at /home/akoski/aek/vhdl/uClinux-working1/nios2-linux/linux-2.6/drivers /base/core.c:123 device_release+0x80/0x84() Device 'altspi.1' does not have a release() function, it is broken and must be f ixed. Stack from cf820e18:<0> <0> cf820e3c<0> c000f8fc<0> cf81dd80<0> c02245c4<0> fffffff0<0> 00000000< 0> c000f980<0> c0211a68<0> <0> cf820e44<0> 00000000<0> c00fb384<0> cf82d880<0> c02201d8<0> c00d4dc8< 0> c02201f4<0> c00d4d84<0> <0> 00000004<0> c00d5758<0> c02201d8<0> c02201c8<0> c00d4cb0<0> c023f3e4< 0> c023f3e4<0> c00fa1bc<0> <0> c00fee30<0> c00fef08<0> 00000002<0> c00fef8c<0> 00000001<0> 00000000< 0> c023fe84<0> c022f998<0> <0> c030d020<0> c022f9f4<0> 00000000<0> c0000210<0> 00000000<0> deadbe00< 0> 00000000<0> c00d3de0<0> <0> c00939c8<0> c0222944<0> 0000004d<0> cf81a0e0<0> c03173e0<0> 0000001f< 0> c0093c6c<0> cf81a140<0> Call Trace:<0> <0> [<c0036684>]<0> [<c0090000>]<0> [<c000252c>]<0> [<c000c1d4>]<0> <0> [<c0002490>]<0> [<c000104c>]<0> [<c0002520>]<0> ---[ end trace 4eaa2a86a8e2da23 ]--- ------------[ cut here ]------------ WARNING: at /home/akoski/aek/vhdl/uClinux-working1/nios2-linux/linux-2.6/drivers /base/core.c:123 device_release+0x80/0x84() Device 'altera_uart.0' does not have a release() function, it is broken and must be fixed. Stack from cf820e18:<0> <0> cf820e3c<0> c000f8fc<0> cf81dde0<0> c02245c4<0> fffffff0<0> 00000000< 0> c000f980<0> c0211a68<0> <0> cf820e44<0> 00000000<0> c00fb384<0> cf82d900<0> c0220124<0> c00d4dc8< 0> c0220140<0> c00d4d84<0> <0> 00000004<0> c00d5758<0> c0220124<0> c0220114<0> c00d4cb0<0> c023f3e0< 0> c023f3e0<0> c00fa1bc<0> <0> c00fee30<0> c00fef08<0> 00000003<0> c00fef8c<0> 00000001<0> 00000000< 0> c023fe84<0> c022f998<0> <0> c030d020<0> c022f9f4<0> 00000000<0> c0000210<0> 00000000<0> deadbe00< 0> 00000000<0> c00d3de0<0> <0> c00939c8<0> c0222944<0> 0000004d<0> cf81a0e0<0> c03173e0<0> 0000001f< 0> c0093c6c<0> cf81a140<0> Call Trace:<0> <0> [<c0036684>]<0> [<c0090000>]<0> [<c000252c>]<0> [<c000c1d4>]<0> <0> [<c0002490>]<0> [<c000104c>]<0> [<c0002520>]<0> ---[ end trace 4eaa2a86a8e2da24 ]--- ------------[ cut here ]------------ WARNING: at /home/akoski/aek/vhdl/uClinux-working1/nios2-linux/linux-2.6/drivers /base/core.c:123 device_release+0x80/0x84() Device 'altera_jtaguart.0' does not have a release() function, it is broken and must be fixed. Stack from cf820e18:<0> <0> cf820e3c<0> c000f8fc<0> cf81de40<0> c02245c4<0> fffffff0<0> 00000000< 0> c000f980<0> c0211a68<0> <0> cf820e44<0> 00000000<0> c00fb384<0> cf801b20<0> c0220070<0> c00d4dc8< 0> c022008c<0> c00d4d84<0> <0> 00000004<0> c00d5758<0> c0220070<0> c0220060<0> c00d4cb0<0> c023f3dc< 0> c023f3dc<0> c00fa1bc<0> <0> c00fee30<0> c00fef08<0> 00000004<0> c00fef8c<0> 00000001<0> 00000000< 0> c023fe84<0> c022f998<0> <0> c030d020<0> c022f9f4<0> 00000000<0> c0000210<0> 00000000<0> deadbe00< 0> 00000000<0> c00d3de0<0> <0> c00939c8<0> c0222944<0> 0000004d<0> cf81a0e0<0> c03173e0<0> 0000001f< 0> c0093c6c<0> cf81a140<0> Call Trace:<0> <0> [<c0036684>]<0> [<c0090000>]<0> [<c000252c>]<0> [<c000c1d4>]<0> <0> [<c0002490>]<0> [<c000104c>]<0> [<c0002520>]<0> ---[ end trace 4eaa2a86a8e2da25 ]--- bio: create slab <bio-0> at 0 NET: Registered protocol family 2 IP route cache hash table entries: 2048 (order: 1, 8192 bytes) TCP established hash table entries: 8192 (order: 4, 65536 bytes) TCP bind hash table entries: 8192 (order: 3, 32768 bytes) TCP: Hash tables configured (established 8192 bind 8192) TCP reno registered NET: Registered protocol family 1 Altera example PIO driver io scheduler noop registered io scheduler deadline registered (default) fb0: Altera FB frame buffer device loop: module loaded i2c /dev entries driver TCP cubic registered NET: Registered protocol family 10 IPv6 over IPv4 tunneling driver NET: Registered protocol family 17 NET: Registered protocol family 15 turn off boot console early03 Replies
I added some printk statements to better understand "resource 2"
atse.0: claiming resource (0 of 5) p:C01CE8D4 bus:platform rtype:mem rname:atse_resource_desc_mem atse.0: claiming resource (1 of 5) p:C01CE8D4 bus:platform rtype:mem rname:atse_resource_sgdma_rx_mem atse.0: claiming resource (2 of 5) p:C01CE8D4 bus:platform rtype:mem rname:atse_resource_sgdma_tx_mem atse.0: failed to claim resource 2 resource 2 is "atse_resource_sgdma_tx_mem".. that's a clue. - Altera_Forum
additional printk shows the start and end addresses:
atse.0: claiming resource (0 of 5) p:C01CE8D4 bus:platform rtype:mem rname:atse_resource_desc_mem rstart:0x11 800000 rend:0x11801FFF atse.0: claiming resource (1 of 5) p:C01CE8D4 bus:platform rtype:mem rname:atse_resource_sgdma_rx_mem rstart: 0x11803C40 rend:0x1180403F atse.0: claiming resource (2 of 5) p:C01CE8D4 bus:platform rtype:mem rname:atse_resource_sgdma_tx_mem rstart: 0x11803C00 rend:0x11803FFF atse.0: failed to claim resource 2 of the failed resource. matching these addresses with what is expected in from custom_fpga.h (SOPC Builder) shows a mismatch. it turns out that config.c had hardcoded the size of the SGDMA RX and TX to 0x400! (line: .end = nasgdma_rx_csr + 0x400 - 1) I changed this to use the SGDMA_RX_END and SGDMA_TX_END instead defined in custom_fpga.h in config.c and it works. - Altera_Forum
Hi,aekoski!I hava a DE3 board(EP3SL150).I want to transplant uClinux to my board.But I do not know what to do.Can you give me some instructions?Thank you very much.
