14 years agode2 webserver template, "full feature".sof error
Hello all, this is my first post after two days searching I cannot find a solution to this sealeslly easy problem I am trying to run the webserver template in nios II IDE, using the provided fu...
14 years agoIf possible, you should start with one of the design examples that work and add the peripherals you need one after the other. The design you are trying to use may have been written for another version of the kit.
