14 years agode2 webserver template, "full feature".sof error
Hello all, this is my first post after two days searching I cannot find a solution to this sealeslly easy problem I am trying to run the webserver template in nios II IDE, using the provided fu...
14 years agoIt may sound stupid but are you sure you are using the correct .sof file? There are several kits that are called DE2.
As for the pin, yes it is weird. Did you check the pin assignement in the kit documentation? Sometimes the documentation is wrong, only the schematic is a reliable source of information.
