19 years agoDE2 Video In SAV EAV
I'm trying to implement a video in/TV in decoder for the DE2 board. Do I need to configure the decoder chip every time I load my design or can I just use the "default" settings? The pr...
19 years agoI've had a similar problem. The input data is a bit noisy.
To fix the problem do the following. 1. Open the assignment editor from the Assignments menu in the menubar in Quartus II. 2. Add a new assignment with the following parameters: To: * Assignment Name: Current Strength Value: Minimum Current Enabled: Yes 3. Recompile your design. Good luck - Blair
