19 years agoDE2 TryOutuClinux
Hi all, I am trying to load zImage_de2_net on to the DE2 board. I have used the DE2_NET.sof to configure the hardware. All goes well untill I run the image using the nios2-download -g zimage...
19 years ago --- Quote Start --- originally posted by bigpunx@Nov 7 2006, 08:16 PM hi all,
i am trying to load zimage_de2_net on to the de2 board. i have used the de2_net.sof to configure the hardware. all goes well untill i run the image using the nios2-download -g zImage_de2_net[/b] command. After programming, the nios shell reports that verification failed at an address that appears to be VGA subsystem. I do not have a SD card on the board yet. Could that be the problem? Thanks everybody! <div align='right'><{post_snapback}> (index.php?act=findpost&pid=19276) --- Quote End --- [/b] --- Quote End --- Hi, bigpunx I used DE2 board and trying to load zImage_de2_net on the DE2 board. It works without problem. You will following "wiki home" steps.
