16 years agoDE2 JTAG_UART terminal_PC communication problem : pausing target proccessor
Hi, I am doing the tutorial creating hello_world for a nios Development Board (niosII Sftw. Developers Handbook - Chap3 Getting started from de command line) Tools 9.1 : nios II EDS -> com...
16 years agoHi,
I have rebuild all and the result dont change. 0-Copy in new work file the nios2eds example project: C:/altera/91/nios2eds/example/verilog/nios2_cyclone II_2c35/standard/* 1-Open QII (9.1 sp1 web edition ips-embedded license)-> open NiosII_cycloneII_2c35_standard project -> SOPC Builder ->automate base-address ->generate project : -warning : using ddr_sdram_0 module version 9.11 and not 9.1 - i can read at sysid module/ the id system and timestamp - sopcinfo file generated 2-Compile QII project - *.sof generated -DE2 cyclone II 2c35 FPGA configure : download *.sof 3-Open nios2 EDS BTS - Workspace : same that QII project - New File : nios2 application and BSP template - Location SOPC : same that QII project - hardware : nios2_cycloneII_2c35_sopc.sopcinfo - Project name: hello_world - ../software/hello_world and ../software/hello_world_bsp created -build hello_world_bsp project -build hello_world project - i can real in public.mk file the id system and timestamp paremeters - i dont understand WHAT IS syslib (¿old IDE file version?) - hello_world RUN AS nios hardware 4-Error: sys id not found at base address ¿ there is some other file from original example that is not upgrade when i build sopc, compile qII project and create hello_world software and bsp? Then makefile and socpinfo are ID matched, why can not execute the download-nios2 *.elf command? I have tried look for other example with sysid peripheral but i dont get it Thanks
