20 years agode2 ,flash programmer help!
when i use flash programmer in ide, a errer is given:
the associated NiosII system library poject fo rght application project is refercing a non-existent sopc buider system file. please select the application project and select project->properties->Asociated system library to choose a different system. i was taught that, de2 is not a standard board, so i have to creat a new flash programmer description for my board by mk_target_board in sdk, as i tryed ,the following response occured, [SOPC Builder]$ mk_target_board --name=DeviceSopc --family=CycloneII --clock=50 --index=1 --buffer_size=16384 --class=DeviceSopc_Flash_Programmer Make Target Board version 1.01 Switch summary: Board name: "DeviceSopc" Board class: DeviceSopc_Flash_Programmer Device family: "Cyclone II" Clock frequency: 50000000hz Payload buffer size: 16384 bytes ERROR: d:/altera/kits/nios2_51/bin/create-board.pl 1279 CALLED (main) d:/altera/kits/nios2_51/bin/create-board.pl 99 CALLED (cb_setup_directories) d:/altera/kits/nios2_51/bin/create-board.pl 511 CALLED (europa_utils::find_com ponent_dir) /cygdrive/d/altera/quartus51/sopc_builder/bin/europa/europa_utils.pm 2016 CAL LED (europa_utils::ensure_class_ptfs) WHERE 'get_class_ptf and ensure_class_ptfs must be called with g{system_directory}' OC CURRED on /cygdrive/d/altera/quartus51/sopc_builder/bin/europa/europa_utils.pm 1 9092 Replies
As of 5.1, mk_target_board was obsolete. Read the Flash Programmer's Guide please.
- slacker - Altera_Forum
--- Quote Start --- originally posted by slacker@Aug 9 2006, 12:15 AM as of 5.1, mk_target_board was obsolete. read the flash programmer's guide please.- slacker
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=17441)
--- quote end ---
--- Quote End --- thank so much for your help
