19 years agoDE2 dev board ->ETH problem
Hi, I tried to put uClinux on a DE2 dev board for one of my school project, and i don't succeed to enable the ETH. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif ...
19 years agoHello,
Yes, your command works, i have the eth0 with a good configuration. I use uClinux-dist-20070130 and the patch uClinux-dist-20070130-nios2-02.diff which is present here (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux/uclinuxdist/uclinux-dist-20070130-nios2-02.diff.gz?cachetime=1170915312300). I haven't got the file dm9ks.c. Maybe it's the reason of my failure http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/mad.gif . Can you send it to me ??? (and if you have the time, can you send me your ptf, or all the thing that i need to correctly compile uClinux ??? http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/rolleyes.gif ) Thanks for your help http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif XREvo
