19 years agoDE2 dev board ->ETH problem
Hi, I tried to put uClinux on a DE2 dev board for one of my school project, and i don't succeed to enable the ETH. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif ...
19 years agoPlease try out the DE2_NET.sof and zImage_de2_net files attached in
http://nioswiki.jot.com/wikihome/operating...s/tryoutuclinux (http://nioswiki.jot.com/wikihome/operatingsystems/tryoutuclinux) It has the dm9ks driver enabled so you play without any compilation. The later sof files in DE2 packages (1.3-1.5) might have some problems in SDRAM. The above sof is from v1.1. You may look at the boot message of DE2 in the page, http://nioswiki.jot.com/wikihome/operating...ems/uclinuxdist (http://nioswiki.jot.com/wikihome/operatingsystems/uclinuxdist) and watch for the probe of the chip, <DM9KS> I/O: 80900090, VID: 90000a46 And you should try out the ifconfig and net services. When you want to config the kernel, select only the dm9ks net driver. [*] DM9000A with checksum offloading
