12 years agoDE2: Control Panel application for Linux
Hello! I am trying to build a random-number generator, but I want to check the output values to see their distribution. I intend to write the random-numbers to the SRAM on board the DE2 board a...
12 years ago --- Quote Start --- I am trying to generate Gaussian samples starting with Tauseworthe Random Number Generators. --- Quote End --- Do you have references on this method? The few Google hits I looked at just showed LFSRs, which would not give you Gaussian noise, and if you've reviewed the link to the LFSRs tutorial, you'll see that you can get Gaussian-like noise, but its not really Gaussian (unless you sum enough uniform distros together so that the central-limit theorem works well). --- Quote Start --- I wanted to respond earlier, but the site seemed down - your response let me concentrate on other things without trying too hard to get Control Panel work on Linux using wine etc, and wasting a lot of time. --- Quote End --- Don't waste your time working with any of the closed-source applications provided with the evaluation boards. Cheers, Dave
