12 years agoDE2-115 schematics don't show EPCS pins
I'm trying to get my hardware/software nios project into the EPCS64 device on the DE2-115 board. It sounds like I need a EPCS controller in my nios project, but when it exports the signals for the c...
12 years ago --- Quote Start --- Ok sounds good. I'll get on that. Are you saying I should get a .pof file working basically? Load through AS via the Quartus II programmer? --- Quote End --- Yes. Your NIOS II core can still be in the design, but if you add a JTAG bridge, then you can use system console to access your design. This would then confirm that booting NIOS II is the problem, rather than the image generation for the EPCS device. Cheers, Dave
