12 years agoDE2-115 schematics don't show EPCS pins
I'm trying to get my hardware/software nios project into the EPCS64 device on the DE2-115 board. It sounds like I need a EPCS controller in my nios project, but when it exports the signals for the c...
12 years agoHey Dave,
Thanks for the info. I finally found them. When I added the EPCS controller to my Qsys project and synthesized it the EPCS controller generated 4 external signals. They are called data0, dclk, sce and sdo. I found all of the pins in the Pin information pdf and Cyclone IV pinout pdf with the exception of sce. I think that is the nCSO though which I also found in there as CSO. So I've gotten all of those connected up now and I've still got a problem. Maybe I can post up my process and you can let me know if you see anything I'm missing because for some reason I can't bootload the nios code. This first way (JIC File) - from the attached NiosII Boot from EPCQ and EPCS in QuartusII 13.0: First I run sof2flash() sof2flash --input="D:/projects/xyz/DE2-115/Onboard_UART_Test/output_files/OnBoardUartTest.sof" --output="D:/projects/xyz/DE2-115/Onboard_UART_Test/flash/hw.flash" --epcs --verbose next i run elf2flash: elf2flash --input="D:\projects\xyz\DE2-115\Onboard_UART_Test\software\DE115_OnBoard_UART\DE115_OnBoard_UART.elf" --output="D:\projects\xyz\DE2-115\Onboard_UART_Test\flash\sw.flash" --epcs --after="D:\projects\MMT\DE2-115\Onboard_UART_Test\flash\hw.flash" --verbose next I run nios2-elf-objcopy: nios2-elf-objcopy --input-target srec --output-target ihex "D:\projects\xyz\DE2-115\Onboard_UART_Test\flash\sw.flash" "D:\projects\xyz\DE2-115\Onboard_UART_Test\flash\sw.hex" I then generate the JIC file: I add the Cyclone 4 EP4Ce115 as the flash loader I added the .sof file from quartus as the SOF Data - I use properties to select compression on the SOF file I then add the hex file produced from the command line above - In this window I choose relative addressing and select the hex file Below is a screen shot of my JIC creation window. The JIC creates with no problems. https://www.alteraforum.com/forum/attachment.php?attachmentid=9481 After this I open up the programmer shown below: https://www.alteraforum.com/forum/attachment.php?attachmentid=9482 This seems to go well too. I find the FPGA and attach the EPCS64 configuration flash to it. I then add the JIC file, check the program/configure box and it programs. My nios and Qsys system screen shots below show how I connected/configured all of that. https://www.alteraforum.com/forum/attachment.php?attachmentid=9483 EPCS Controller settings https://www.alteraforum.com/forum/attachment.php?attachmentid=9484 NIOS II Settings - continued on next post b/c of JPG limit
