12 years agoDE2-115 schematics don't show EPCS pins
I'm trying to get my hardware/software nios project into the EPCS64 device on the DE2-115 board. It sounds like I need a EPCS controller in my nios project, but when it exports the signals for the c...
12 years agoThe EPCS device pins are fixed, i.e., you have no choice as to their pin assignments. The EPCS device is used for Active Serial (AS) configuration, and then once the FPGA enters user-mode, you can access the EPCS device as user SPI flash. If you add the Altera EPCS flash IP core into your design, eg., Qsys, I don't think you need to make any pin assignments, otherwise you can just look at the pin planner view and note which pins correspond to the AS pins and use those in your assignments. Sometimes the Terasic schematics do not show the configuration device page (since it also includes the USB-Blaster circuit).
Cheers, Dave
