13 years agoDE2_115 Board not respond to ping request
I have run the simple_socket_server example on ALtera De2_115 board , though my code run's without any error but wont respond to my ping request from other PC it says Host unreachable. i have attache...
13 years agoIt looks like the software is crashing and boots again. I don't think this is a hardware problem, because if the FPGA reconfigured itself for some reason, then the console would have lost contact with the Jtag UART.
What do you mean by "activity"? Are you sending a lot of packets? Is there a special type of packet that makes the application crash? What exactly happens after the "Sending Data at RS232 port at 115kbps..." ? Did you try to run that part of the code with a debugger?
