13 years agoDE2_115 Board not respond to ping request
I have run the simple_socket_server example on ALtera De2_115 board , though my code run's without any error but wont respond to my ping request from other PC it says Host unreachable. i have attache...
13 years agoIt is really hard to give a generic answer, it could come from a lot of different places.
If you try with the standard design delivered with the kit, does it work? Is the IP address shown there a static one that you gave the card or is it coming from dhcp? Can you use a sniffer tool such as Wireshark to see if anything is going to the board or coming from it? If you set signaltap probes on the avalon streams to/from the TSE is there anything going on there?
