10 years agoDE1-SoC MSEL [00000] or [01110] Unable to program FPGA from HPS
Hello together,
I'm just getting started with my DE1-SoC, and I seem to be unable to program the FPGA from Linux w/ frame buffer or LXDE/UBUNTU. I have set the correct MSEL[4:0]. root@socfpga:~# ERROR: Incompatible MSEL mode set. Cannot continue with FPGA programming. If I program the FPGA from Linux w/o frame buffer (01010), it works fine just as configuring from EPCS (10010). Am I missing anything, or is there a way to test where the problem is? Thanks,4 Replies
--- Quote Start --- Hello together, I'm just getting started with my DE1-SoC, and I seem to be unable to program the FPGA from Linux w/ frame buffer or LXDE/UBUNTU. I have set the correct MSEL[4:0]. root@socfpga:~# ERROR: Incompatible MSEL mode set. Cannot continue with FPGA programming. If I program the FPGA from Linux w/o frame buffer (01010), it works fine just as configuring from EPCS (10010). Am I missing anything, or is there a way to test where the problem is? Thanks, --- Quote End --- you may try with MSEL[0:4] is 01010.hope it will work. - Altera_Forum
Hi!... There is a difference between generate rbf with compression or without. If you use compression MSEL need set MSEL[0:4] 01010 without MSEL[0:4] 00000 I test this with de1-soc and linux frame buffer with ubuntu in a sd. I need help with the tree. I have to generate manually my ip's created with qsys and I don't know how. Thanks!
- JMuno5
MSEL[0:4] = 00000 worked for me, thank you!
Hi vinaysrivastava, thanks for having a look. MSEL[0:4] 01010 only works for Linux without frame buffer (the linux_SD image), not LXDE or Ubuntu. If I use the previously mentioned MSEL I don't have a framebuffer.
