10 years agoDE1-SoC MSEL [00000] or [01110] Unable to program FPGA from HPS
Hello together, I'm just getting started with my DE1-SoC, and I seem to be unable to program the FPGA from Linux w/ frame buffer or LXDE/UBUNTU. I have set the correct MSEL[4:0]. root@socf...
10 years ago --- Quote Start --- Hello together, I'm just getting started with my DE1-SoC, and I seem to be unable to program the FPGA from Linux w/ frame buffer or LXDE/UBUNTU. I have set the correct MSEL[4:0]. root@socfpga:~# ERROR: Incompatible MSEL mode set. Cannot continue with FPGA programming. If I program the FPGA from Linux w/o frame buffer (01010), it works fine just as configuring from EPCS (10010). Am I missing anything, or is there a way to test where the problem is? Thanks, --- Quote End --- you may try with MSEL[0:4] is 01010.hope it will work.
