10 years agoDE1-SoC MSEL [00000] or [01110] Unable to program FPGA from HPS
Hello together, I'm just getting started with my DE1-SoC, and I seem to be unable to program the FPGA from Linux w/ frame buffer or LXDE/UBUNTU. I have set the correct MSEL[4:0]. root@socf...
9 years agoHi!... There is a difference between generate rbf with compression or without. If you use compression MSEL need set MSEL[0:4] 01010 without MSEL[0:4] 00000 I test this with de1-soc and linux frame buffer with ubuntu in a sd. I need help with the tree. I have to generate manually my ip's created with qsys and I don't know how. Thanks!
JMuno5
7 years agoMSEL[0:4] = 00000 worked for me, thank you!
