15 years agoDE1 Flash access problems
Hello forum,
I'm a beginner with NIOS II. I've successfully tested RS232 communication using the uart component in SOPC, however I'm having a hard time with the CFI flash. This is my configuration: SOPC block diagram: http://i52.tinypic.com/2znyc77.png flash configurations: http://i53.tinypic.com/314auyh.png pin planner: http://i53.tinypic.com/4hqbyg.png alt_pll is shifting the SDRAM and Flash clock by -6ns. SDRAM works fine though, unlike the flash. I've tried a different phase shifts for the flash's clock but I fail to nail the right one, maybe. If a phase shift is even needed... I've no idea! I'm using the following C code (from Nios II Software Developer’s Handbook page 160):# include <stdio.h># include <string.h># include "sys/alt_flash.h"# define BUF_SIZE 1024
int main() {
alt_flash_fd* fd;
int ret_code;
char source;
char dest;
/* Initialize the source buffer to all 0xAA */
memset(source, 0xAA, BUF_SIZE);
fd = alt_flash_open_dev("/dev/cfi_flash_0");
if (fd != NULL) {
ret_code = alt_write_flash(fd, 0, source, BUF_SIZE);
if (ret_code == 0) {
ret_code = alt_read_flash(fd, 0, dest, BUF_SIZE);
* Success.
* At this point, the flash is all 0xAA and we
* have read that all back to dest
alt_flash_close_dev(fd);
} else {
printf("Cannot open flash device\n");
return 0;
It seems that fd == NULL for some reason. I hope you can provide an explanation... :( I'm sure the problem is somewhere in my HW settings (timing most likely, could be pins too though). I just can't nail the right configuration.No RepliesBe the first to reply
