16 years agoDE0:Customize Kernel Settings
HI,everyone ! I want to Customize my own uCinux kernel on DE0.I make menuconfig in the uclinux-dist directory and select the Customize Kernel Settings.IN Processor type and features\Platform a dev...
16 years agoIt's very kind of you to reply!:)
I have successfully transformed uClinux to my DE0 board under default settings. I start with a minimum hardware systems. But you know ,the IO pins and chips on DE0 board are quite diffrent from those on DE2 board and other boards supported by nios2-linux.As a result ,the device drivers may not apply to DE0 board!
